De smoged 22R (1 Viewer)
I can try to get you some pics tonight if you want. Anything in particular?
I found that taking all the smog junk off made it run a bit stronger but it killed the fuel mileage by 5 mpg. I may not have had the carb hooked up exactly right, but it was screwed up anyway. Weber fixed the problem. If you have a vaccuum diagram, pay attention to where you need vacuum at the carb and when. Some ports can be plugged but others will make your life hell.
Good luck.
Dan
I used the stock carb until switching to the weber, but the older you go, the less ports there are. However, I don't know what the cfm rating is on any of those carbs
