De smoged 22R (1 Viewer)
Virginia Beach, VA
I found that taking all the smog junk off made it run a bit stronger but it killed the fuel mileage by 5 mpg. I may not have had the carb hooked up exactly right, but it was screwed up anyway. Weber fixed the problem. If you have a vaccuum diagram, pay attention to where you need vacuum at the carb and when. Some ports can be plugged but others will make your life hell.
Good luck.
Dan
Virginia Beach, VA
I used the stock carb until switching to the weber, but the older you go, the less ports there are. However, I don't know what the cfm rating is on any of those carbs
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
