De-flared poll: weld them shut or just paint over the plugs? (1 Viewer)
Weld the holes first, or just paint over the plugs?
  • Total voters
    19
  • Poll closed .
Spokane, WA
I lined over nylon plugs after WAY too much deliberation. If I did it again, I would use the foil tape - I used some on the square holes in the rear and it is hardly noticeable.
PNW
Anyone have a Slee ShortBus and rear bumper without flares?
Short bus fits great w/o flares.
Actually sticks out maybe an inch. Much better than an ARB
...via IH8MUD app
bryson
I do stuff.
Utah
I would vote for option #3 - Foil tape. Mine are welded and smoothed because I was doing a full paint job, and I didn't bed-line as high as the flares were, so the holes wouldn't have been covered with the liner.
Dirty Koala
Draper, UT
I have no intention of ever selling my cruiser, plus I already had a welder and the skills to use it, which made my decision to weld pretty easy. I did get a quote from a local shop, mostly so I knew what I was saving by doing it myself. They wanted $2k to weld up the 50 flare/trim holes plus the 16 roof rack holes...and that was assuming I dropped and reinstalled the headliner and sunroof for them.
Jose - For $100 you were paying that guy below minimum wage...you lucked out there my friend.
Atlanta, GA
I started welding up the holes a few days ago. It didn't take more than just a few hours to get all the holes done but the ones on the rear doors. If you decide to weld up the holes I would suggest getting a copper welding spoon to create a barrier to stop blow through, and also take out the heat which will cause thin gauge metal to warp. I used a 1/8" piece of copper plate and a magnet to hold it on the panel behind the holes, which worked perfectly.
Colorado Springs
After researching and talking with multiple body shops in Kansas City, it's $300/panel for a total of $1,800. That includes welding the twenty holes shut, sanding the panels down, matching the paint.
Needless to say the flare gaskets have been replaced and the they are all back on. I'll save this project for another day.
Lethbridge AB, Canada
Not sure about the LC's exactly but on the LX's you wont have access to the back-side of all the holes. This means you cant cover those welds up and they could start to rust. I had all of the rear-accessible holes welded and used a "Muggy Weld" type product for the other holes.
After the holes were filled:
by RickaShay24, on Flickr
Now (also note the width of the Slee front):
Missoula, MT
@nukegoat @Enigma
I don't suppose you guys have a closeup shot of these holes without closing them up? I was thinking about taking flares off and leaving them until years down the road right before I repaint.
Same boat....been on my "to do" list since I tore mine off in 2011. I refer to them now as lightening holes, to offset the hundred's of pounds of extra steel that has been added......
LFD2037
TEXAS LEXUS!
Wax., TEXAS
Is your original paint black or dark green? What color did you use for the, I'm assuming, Monstaliner? Any better pics of the width of the Slee deflared? Thanks.
