daytime running lights module
oops
sorry the wire that supposed to be conected to spark plug wire(in diesel nothing like that)instruction says that this wire must be conected to oil pressure switch-where is the oil pressure switch?thanx dupa
You can connect the wire to ANY 12v Hot-On-Run source...the oil pressure switch is just a suggestion. If you have an easier to reach source you can use that instead. On my Hilux Surf I used a parasite tap from the CHARGE fuse in the fuse box in the engine bay as my 12v Hot-On-Run source for example.
I did a post on the JDM Alliance board here a few months back on an easy way of adding DRL's to my 1991 Hilux Surf...if you search 'DRL' you should find it. There are pics of where I grabbed power so that might help you.
