Having trouble with the rear brakes on my Datsun D21 ute/pickup.
Rear hubs are heating up to the point where the wheel rims are hot to touch after driving any significant distance (10km+). This started after mechanics replaced the brake drum pads, but this might just be coincidental though.
After this was initially noticed the handbrake was adjusted and it is definitely not contacting the drum (vehicle is able to be easily pushed back and forth with handbrake off), however the problem with the hubs heating up persisted.
Handbrake cable and rear brake line were replaced today to try and fix it, but the problem still persists.
Wheel bearings have also been checked as a possible cause, they're fine (although the grease will likely be degrading with all the heat going through it).
Next stop is the brake master cylinder. Theory is that it's possibly preventing back flow of fluid after releasing brake pedal, which is causing the brakes to rub slightly. It's only effecting the rear though so I have my doubts.
Anyone have any other suggestions?
