Hi all,
On the weekend my HDJ81 started acting funny whereby the dash lights (turbo/overboost, AT Oil Temp, Tbelt, charging light) continue to be lit after starting. I searched here and found that flickering dash lights tend to indicate a failing alternator or an issue with grounds but mine aren't flickering. When I start the truck and return the key to the 'run' position the lights turn off momentarily (about 1 sec) and then turn back on with no flickering. Does this still sound symptomatic of a failing charging system? The other bit of info that may be relevant is I've been having more trouble getting my key into the ignition...it's kind of "sticky" when I push it in. Is it possible there is a contact issue within the ignition barrel causing the lights to go out and then come back on? Any assistance you could provide would be greatly appreciated!
Cheers,
Mike
Cheers,
Mike
