after much way to much use of the search bar and a few phone calls i am throwing myself at the forum.... i Have had the slee harness and and IPF HIR bulb set kicking around and finally got to installing it yesterday.... ....... re-set all the wires.. checked all conections. checked all grounds, i hooked that battery back up. I turned the key, turned the lights on and as they went on my dash lights went out.... i go to check to lights and my DS low beam is dim....(like i left my battery on and it didnt have any juice) and the other one wasnt on? WTF? so i turn the vehicle off... disconect the batttery and fix the PS side connection.. the harness that hooked into the light was loose (the gound wasnt seated properly in the light end) so i fixed. the DS is a whole nother story..... i check all conections and try again with same results.. all lights work now excet DS low.. its lighting up but super dim.... also... after checking fuses i cant find a bad one... i only checked the fuse tray behind battery and the fuse tray under the diff lock that is by your knee when your sitting.... am i totally missing something.... to clarify the dash lights i dont have are the lights that come on when turning your headlights on. clock works.. radio works. my main question is why the dash lights went out? how do i fix them.? the DS dim has to be a bad bulb Becuase i put my old light in and its great... ....... so there you have it.... i am at your mercey.. tell me i am a newbie and i will tell you to and we will all be happy.... thanks for your input in advance.....
