Dang IT! (2 Viewers)
Virginia Beach
My dilemma in mounting my Metal Tech Sliders that I just picked up. I have an extra bracket that was put on when I got my lift. Do I need it? I believe it is there to keep the caster? angle correct. Can I remove it and not effect the angle to bad? I have a 3 inch lift with J springs.
your mom
and land tank
What bracket is that? Who makes it?
Who is in the background?
you "might" be able to notch the man a fre bracket so the ubolt can fit through, would have to see it in person.
Noah
Thought about that but there is not enough room for the bolt to go through.
I got some new castor bushings that I'm not using. They're FOR's bushings and I think they're for 3" lift.
You can give these a try and if they work, give me maybe $50 for them. If not, take them off and go for plates, Slee's or LT's.
there's no way that will be notched and retain any strength.
Ditch the MAF stuff.
3" lift you would be fine with castor bushings or plates. If it were me I would sell the MAF brackets, get some bushings or plates and enjoy the extra ground clearance and Metal Tech protection. But that is just me. :grinpimp:
