- Location
- United States
Located in Vacaville CA 95687
Text- seven zero seven 592 one nine three six
Buyer pays shipping
View attachment 1416041 View attachment 1416042 View attachment 1416045 View attachment 1416046 View attachment 1416049 View attachment 1416041 View attachment 1416042 View attachment 1416045 View attachment 1416046 Narrowed dana 44 front axle set up for spring over FJ40 land cruiser . 6x5.5 lug pattern . 4.09 ring & pinion(will work with4.10,&4.11) ARB air locker . This came out of 3/4 ton chevy so it has 1/2" thick axle tubes. Knuckles were jigged up by currie ent. Cross drilled rotors high perf brake pads, 1/2 ton chevy truck calipers warn hubs , warn diff gaurd . New ball joints ac delco professional grade. Tri county gear high steer arms . 1 ton tie rod and drag link . New spicer lifetime ujoints . Comes with spare inner shafts(short side inner spare is dutchman chromo) long & short side. 3 spare outer shafts ujoint installed on one of them , spare spindle and hub and lock nuts , spare tierod assembly , spare ball joints 2 lowers 1 upper , 1/2 ton high flex long travel drive shaft ( course spline) can throw in two 2" wheel spacers as well , 1 spare axle u joint greasable kind . Spare se of superwinch locking hubs , ubolts and plates . This is ready to bolt in a spring over FJ40 . This is a package deal dont want to separate . This axle has handled 36" tires for 20 years , but Im finally going to 42" tired so building a 60 . $1600 for the whole package.
Buyer pays shipping
$1100 OBOView attachment 1416041 View attachment 1416042 View attachment 1416045 View attachment 1416046 View attachment 1416049 View attachment 1416041 View attachment 1416042 View attachment 1416045 View attachment 1416046 Narrowed dana 44 front axle set up for spring over FJ40 land cruiser . 6x5.5 lug pattern . 4.09 ring & pinion(will work with4.10,&4.11) ARB air locker . This came out of 3/4 ton chevy so it has 1/2" thick axle tubes. Knuckles were jigged up by currie ent. Cross drilled rotors high perf brake pads, 1/2 ton chevy truck calipers warn hubs , warn diff gaurd . New ball joints ac delco professional grade. Tri county gear high steer arms . 1 ton tie rod and drag link . New spicer lifetime ujoints . Comes with spare inner shafts(short side inner spare is dutchman chromo) long & short side. 3 spare outer shafts ujoint installed on one of them , spare spindle and hub and lock nuts , spare tierod assembly , spare ball joints 2 lowers 1 upper , 1/2 ton high flex long travel drive shaft ( course spline) can throw in two 2" wheel spacers as well , 1 spare axle u joint greasable kind . Spare se of superwinch locking hubs , ubolts and plates . This is ready to bolt in a spring over FJ40 . This is a package deal dont want to separate . This axle has handled 36" tires for 20 years , but Im finally going to 42" tired so building a 60 . $1600 for the whole package.
Buyer pays shipping
$1100 OBO
