Dana 300 and stock speedometer...
Pagosa Springs, CO.
How many of you guys are running a d300 tcase, and have any of you successfully plugged in your stock speedo cable to it?
I read on pirate that they should plug right up, but I'm not seeing that on my end.
I understand that with my oversized tires that any reading I get will be wrong, but I'd still like to have it working.
Any suggestions?
Poser
Oh...Durka Durka Durka.
s-Moderator
Supporting Vendor
MN
Advance Adapters used to have the Atlas manual online, you may want to contact them and see if it is still available out there, I have not been able to find it.
In this, they list out speedo drive gears depending on 'advertised tire size' and rear end gear ratio in a chart. I then called a Jeep dealer, told them I had an 1985 CJ-7, and wanted a speedo drive gear that had 33 teeth. That seems to work for me and my 42" swampers.
What size tires are you running, or looking to run?
I just found my Atlas install manual, and have it in front of me....for some reason ;)
Hope that helps some.
Good luck!
-Steve
Poser
s-Moderator
Supporting Vendor
MN
Not without changing one end of the cable, and changing out the drive gear.
Good luck!
-Steve
