Dan, probs with a fs46
Nashvegas
It cranks and idles fine. Once you take it off idle it stumbles and dies. Pulled the tank and the filter is clean as is the air filter. Could there be a piece of trash stuck in the jet? Fuel pump dying?
No, it sounds normal. I forgot to add that is throttles up fine if the choke is partially closed.
Your comment about throttling up under choke is the key. You have an air leak. Either in the fuel line, carb boot or crank seals. Start at the tank and start ruling out possibilities from there.
Thanks, it was one of my co-workers. He went and bought a new one just like it.
does it have to small screws in the side of the carb with a plastic guard on them then one larger one at the bottom of the carb? (recoil side)
If so pop the platic caps off of the smaller two and turn the screw out a 1/2 turn.
sounds like a blockage in your carb.
If you have one of the lesser desirable carbs with only one small screw in it the only thing you can do is pull it apart and hope you can get the jets cleaned. With fixed jet carbs there is no opening up the high speed jet any more than OEM settings :(
