Dakota VHX Cluster: Parking Brake Warning Light
Quick Question, I have a 68 with a DD and love it….I have always wanted to hook up a switch to the hand brake but the 68 did not have a switch….is there a Toyota PN for a switch that connects to a pull type hand brake….or will any spring pull switch work,,,where contacts open disengage/contacts closed engaged?
On the VHX there is a manual calibration for the fuel sender. It's in the setup manual. You just need to have the sender out of the tank and move the float as prescribed in the instructions.
Yeah I’ve done that on all of them with less than optimal results.
It's working on mine. However, when I fill to the top, it gives me an error until I burn some off, 10 miles or so. I've re-calibrated several times, bent the float arm a little, but didn't help much. Factory sender. Other than that, seems to be fine. Wondering if a new sender will cure it.
