Dakota Digital with H55F speedo cable help
Lancaster, CA
Hey everyone,
Has anyone hooked up a Dakota Digital to an H55F? Is the speedo cable that comes with the kit all you need? When I look at the plastic square male on the cable from the kit there doesn't seem to be a matching female counterpart on the t-case? Am I missing something?
thanx
Craig
The speedometer Drive gear with the female square reciever u are looking for goes in the upper LH side of the Rear seal extension
Housing shown here
u might need the Drive Gear Kit if all u have is the Hole where is goes ?
its like a 17mm bore if i recall correctly
its held in by a flat metal Tab / Retainer and a 12mm hex very short SEMS bolt
1968717
sorry for the SOR SPAM , but only image i could find on short notice of where the Drive Gear Kit Sleeve installs
Mine came with a small brass piece that adapts the square drive to a keyed end which fits the into the splitcase extension housing. Hope this helps.
Ok, that's what that little piece is for....thanx!
