FishTacos
Full Globetard
2 d 8 d40 carburetor from a '68 40 so I guess it isn't the original carb ('72, '82 even???)
I have a 74 engine in there and I believe it has a '68 I/E manifold but I'm not really sure. It does have the adapter bit for the 1bbl carb and the firing order in the intake casting toward the #1 cylinder....
I have two questions. First, the rebuild kit was without a step-up-rod (the little thing that looks like a shepherds crook that fits into the main jet and moves in concert with the pump plunger)
Can I run without it?
Second, what do these two figures mean in the FSM with regard to the "throttle valve" position? I don't understand how to check this adjustment. SST needed? Is there a trick?
I guess that was four questions. I will post pics shortly as they're on my phone.
