D@MN bikini top won't stay on (1 Viewer)
Tulsa, OK
Folks,
I have the Besttop bikini top and windshield channel. Both are brand new. Perfectly straight windshield. However, for some reason I cannot stop the bikini top from blowing off from the front. I have been looking for some ideas as to the best way to hold this thing in place... even read a thread or 2.
Any suggestions?
JOnny
Richmond B.C.
Are you pulling the tension straps down as taught as possible.
Where did you install the footman loops.
What kind of roll bar do you have.
Have any pics of the front channel.
At what speed is the top blowing off.
yzftaco
Goofy-Goober
Menlo Park, CA
Best I can say is pull it taught.. I've had mine come off on the highway as well.. It sucks when that happens!
It happens when the top pillows up (like a convertible) It creates slack and then pow the front comes off..
Edit: another possible cause is at speed the wind is pushing the windshield backwards which also creates slack on the top...
so essentially pull that thing tight.
pb4ugo
spay-lay-wi-theepi, Ohio
I had the same problems w/bestop too. I eventually went w/the Kayline style bikini top. I saw a post not to long ago that someone else is making that style again. It has a different channel & a cord sewn in the top for the windshield attachment point.
Escondido, CA
The title of this thread is misleading. I want my money back.
kling-on
Kool Arrow
Pimpin part in SanAntonio TX
Website
www.texas4x4.org
you have to "fold" it over and put BOTH the cloth and plastic in ... I had to "tap" mine in with a hammer LOL
Tulsa, OK
I'm trying to :)
1. Back corners
2. Smittybuilt
3. Not right now - it's at mechanics.
4. > 30mph
OK - I will make sure to do that, although I am pretty sure it won't go much tighter...
I just spent the money on these so I really don't want to have to buy other news ones right now...
If it would make you feel better I could borrow my girlfriends bikini and put it on... although I can assure you that it wouldn't make you feel any better :eek:
Hmmm. I didn't think of this. Seems like it would just puill straight back out once you pulled it tight...?
Thanks guys,
Jonny
Shark56
Dover, DE
I had mine pop off once but that was behind a motor home about 65 mph. I have run 60-65 with no problems. Is your windshield flexing back as was suggested by wzftaco. Mine will flap quite a bit at those speeds but it doesn't come out of the channel. Its at leats 5 years old.
rusty_tlc
Dain Bramaged Member
Reno, NV
Website
forum.ih8mud.com
I've heard that Wine coolers make bikini tops fall off, I'm just sayin' :hillbilly:
A couple of distributors site have install videos, you might hit a few and find out what yousee.
nuclearlemon
not an addict
Moderator
windy wyoming
check to make sure the spacers that go between the dash and the windshield frame are there to keep the frame from flexing back
Fort Collins
I am with Ige. Keeps the windshield more static.
Mine will get floppy and loose when it warms up and expands. :hmm:(No Pun Intended)
Sometimes I need to adjust the top two or three times as the temps warm up during the day.
NSW, Australia
Line it with rachel mesh or even nylon shadecloth to reduce the ballooning effect. I made a bikini top out of marine vinyl and had all sorts of problems until I lined it.
Central Cal.
When I installed mine for the first time, I put the channels on upside down and it would come off at speeds over 30-40 mph. Once I flipped the channels over so that the channel part is "down" I never had a problem with it again. The plastic tab piece should rotate slightly in the channel once the straps are pulled tight to kind of lock it in place.
You shouldn't have to roll some of the fabric into the channel to keep it secure. I would think that the edge of the channel would eventually cut the material.
San Jose CA
Had the same issues. Just got some 2" nylon strapping and buckles, made a simple strap and put it over the bikini top and roll bar...side to side roughly over the driver's head. Never had a 'pop-off' after
Poser
Oh...Durka Durka Durka.
Supporting Vendor
MN
Folks,
Any suggestions?
JOnny
Post up some pictures of how you have the windshield channel and the top installed.
DSRTRDR
I can mangle anything ...
Baton Rouge, LA and Fountain Hills, AZ
pics would help
I use a real simple solution: get a plastic ensheathed metal rope at the hardware store and thread it through the channel in a way it packs the bikini top into the channel - make a loop at the end of the metal rope, attach a mini hose clamp/rope clamp on both sides, use wingnuts to tie them down at the OEM window frame button points
I modified my Bestop softtop to have a channel for the metal rope - and I made my bikini to have one in the first place
total cost of needed additional materials runs around $7.44 :hillbilly:
Monroe, WA
Thanks guys,
Jonny
^^ this part makes me think you have the windshield channel installed backwards. Is the opening to the front or to the rear?
