Diff support bushings. Ones you bought preassembled@katit which bushings are you referring to?
@Jczajka What a fn mess! Not sure what to tell you about that chip on the hub face. Looks substantial enough to allow water inside to the wheel bearings, even with a new flange gasket. Cheap fix may be to add some gasket maker (FIPG) to fill in the chip before you place the paper gasket on, though the efficacy of that may be ephemeral. More permanent fix may be to weld in a bit of metal to fill in the chip and then grind it down so it’s flat with the rest of the hub face. Alternatively, I’m sure you could find a good replacement at a junkyard (car-part.com).
