cutting the rear x-member off to incorporate
Discussion in '60-Series Wagons' started by 2badfjs, Feb 26, 2007.
  1. 2badfjs
    2badfjs
    5,522
    4
    Jan 26, 2005
    in the garage
    a reciever hitch in the bumper.
    if you were to cut the rear x-member so a bumper w/hitch could be mounted, could the mounting of the hitch act as a new x-member? as long as it mounted from rail to rail?
    thoughts please, looking to possably put this in my bumpers.
    jim
  2. phoenixrider
    phoenixrider
    359
    Feb 21, 2006
    I've seen pictures of this, and that's what I wanted to do on mine. I also wanted to cut off the last couple of inches of frame rail so the bumber will fit in tight. Don't know if anybody has done that
  3. SLOwag
    SLOwag
    349
    1
    Jun 16, 2005
    Yep. That's how 4+ is done. You could just remove the x member by removing rivets (in theory it could be put back.....). Pm me if you need pics.
  4. 2mbb
    2mbb SILVER Star
    4,648
    120
    Sep 1, 2003
    WC, CA
  5. brian
    brian SILVER Star
    8,717
    2,148
    Feb 7, 2003
    lebanon,pa
    i chopped mine on acount of rust issues.
    hard to tell in the pic, but i cut back everything back so that it's right below the tailgate. replaced it with a 4 1/2'' pc of 1/4'' flat bar about 1/2'' wider than the frame rails. to that i mounted teh new bumper, which for now is just something i pulled out of my ass till i figure what i want to do for ''real''.
  6. oilcan
    oilcan
    114
    Feb 8, 2005
    Murray, UT
    I removed my x-member rather unexpectedly...
    :lol:
    Initially, I had cut a hole in the x-member with a torch, and welded in a reciever, which worked great, until I got a little too vigorous trying to pull out a tree.
    I have since built a rear bumper that essentially replaces it. However, this 60 is now a trail rig only, with little to no regard given to longevity. Had this been a DD, much more beef would have been built into bumper/x-member.
  7. Tinker
    Tinker
    2,865
    9
    Apr 15, 2004
    Larkspur, CO
    Jimbo -
    Can you just enlarge the hole in the middle? That's what I did.
    I think you might be able to build a bumper that would be as strong as the old bumper/crossmember combination.
  8. Spook50
    Spook50 Get ready
    4,964
    789
    Feb 16, 2005
    Spokane, WA
    I think that's how 4x4Labs does theirs too is by completely removing the crossmember and using the rivet holes to bolt the crossmember they've integrated into their bumper to.
