Cut and weld or trim and weld?
Michigan
Visit site
Hi I'm looking for some thoughts on the most economical way to address the rear quarter panel rust. Is it more economal to buy the left and right side pre cut quarter panel for 400$ for both just cut and weld in the new rear quarter panels or with the existing ones cut them above the rust and cap it with a piece of metal?
Eastern Washington
Visit site
If just dollars being considered probably cheaper to just cut out the rust and weld in sheet metal. However, the cut sections of actual quarter panel will probably look better.
I suppose trim and weld is a good option if you wanted some more clearance on the sides for a rear bumper...
Michigan
Visit site
Cost is a concern I'll be having a new rear bumper covering the cut anyways. Thanks you.
Eastern Washington
Visit site
Be mindful of the wiring in those panels. Also I think there may be a drain for the sunroof on one side (passenger on mine) so be sure to address that if you have one. Probably need to add a way for the panel to drain too like the stock ones have or you'll get them full of water and have rust issues again.
