Has anyone ever cut & turned a rear axle on a 93+ 80 series? Just wondering if there is anything tricky I've done fronts before etc. I assume it's the same sort of setup out back just looking for possible pointers.
As long as it work on flat dry pavement it'll pass inspection, so it needs to be "functional"Wait, your e-brake works?
I'll be putting a nice big filler up higher and at ring teeth so I can inspect, and you don't really need to over fill but when you tip it up at pinion your fill plug lowers too much so it's actually under capacity.With an "off-caster" rear axle there's apparently an edge case involving lubrication failures on the pinion bearing as well, but you can fix that by overfilling the axle housing.
