Current draw
Discussion in 'Diesel Tech / 24 volts' started by fluffybunnysui, Feb 22, 2009.
  1. fluffybunnysui
    fluffybunnysui
    224
    Sep 8, 2008
    S.Texas
    I was cleaning the terminals on my diesel yesterday and when i went to reinstall the cables, i heard a small little sparking sound. Sure enough, when i touched the heavy black wire(10 awg maybe) back to the positive terminal of the battery i got a pretty good little spark. The keys were out of the ignition and everything was off but i still am getting some sort of current draw. The first thing i checked was the wire going to the glow plug buss bar. I unhooked it from the bar, and touched the black wire back to the positive terminal and no more spark. So now i figure i'm getting 12vdc all the time to the glow plugs.
    I grab my meter and do some checking...
    Here i hooked the + meter lead to the glow plug wire..
    [​IMG]
    And here is the - meter lead to the - battery terminal...
    [​IMG]
    Here are the keys in the seat with nothing turned on...
    [​IMG]
    But yet i'm still getting 12vdc...
    [​IMG]
    Do i have a stuck relay? I have a relay mounted on the floor board of the passanger side... is this where i need to start?
    Thanks
    Cody
  2. KOOTENAY KRUZER
    KOOTENAY KRUZER
    698
    6
    Feb 25, 2007
    Nakusp, BC - in the west Kootenays
    I am not familiar with the HJ45 but that is where the relay is for the BJ40s. The Superglow relays for my BJ42 are in the same general area, too.
  3. MrMoMo
    MrMoMo That's not rust, it's Canadian patina...
    2,451
    Media:
    14
    Albums:
    1
    968
    Nov 11, 2005
    ~Kingston, ON, pero soñando de Panamá
    Can that fluke measure how many amps you are drawing? I would guess that it is more likely a radio memory that is causing the small spark. (not sure how it is backfeeding the glow bar though)
  4. ozwallaby
    ozwallaby
    625
    427
    Jan 25, 2007
    Qld, Australia
    It's a trick... the keys are in the ign. and turned on when you get the reading... that's an old one..... :hillbilly::hillbilly: Don't you think anyone will believe you unless you have a foto...... heh heh
  5. fluffybunnysui
    fluffybunnysui
    224
    Sep 8, 2008
    S.Texas
    I wish ! Turns out that one of these relays (not sure why there are two of them) was stuck in the closed position.
    [​IMG]
    It ended up being the bottom relay, so i slid a knife blade in between the points to free it up. I will pull it off tonight and clean both set up properly.
    [​IMG]
    Here is the cover for the relays i found in the glovebox.
    [​IMG]
    Thanks for the help :cheers:
  6. KOOTENAY KRUZER
    KOOTENAY KRUZER
    698
    6
    Feb 25, 2007
    One relay gives you glow when the glow switch is on, the other one gives you glow when the key is on start.
    I cleaned mine up with a fine diamond coated nail file then polished them with crocus cloth, that was a few years ago and they have been fine ever since.
