Cruiser parts purge-all parts are gone
Albuquerque, NM
OK, the purge has begun! much of this is free, come take it if you want it. some of you will believe what I have amassed, some may not, but here's 20 years of parts collecting.
various switches and electrical
Wiper motors
FJ40 gage clusters
spring shackles with some minorly damaged threads
selectro hubs (I have the set, have to find the other one. may have 2 sets)
swing out tire carrier parts and hinges
a cruiser Tcase (not sure if it's 3 or 4 speed variant, I think it came off my 4 speed)
shock towers
motor mount brackets
spring top plates
whatever else you see here all free
single cylinder brake and clutch cylinders and parts
checvy monte carlo brake calipers for a rear brake conversion
1 bad condition front park ight/turn signal
Power steering hose
gages from a cluster
5th gen 4runner stock rear coil springs
Also have the front stock coil overs with shocks
15x10 aluminum wheels cruiser/chevy 6 lug- clears FJ40 front calipers $100 for all 4
1979 distributor and coil to upgrade stock, earlier ignition to electronic $75
dizzy cap and rotor not sure if it goes with the above, but is brand new $15
chevy small block- block hugger headers, ceramic coated and 3/8 inch thick flange at manifold $500 with gaskets
lots more to come as I get to it in the garage
85 FJ60 heater blower
igniter
rear view mirror
fuel evaporator parts from just outside fuel tank
FJ40 sun shades
77 FJ40 alternator
77 FJ40 coil and ignitor
all free
FJ60 parts
AC compressor $50
carburetor $10
smog pump $50
emissions air rail and tubing- free
FJ60-
intake manifold
fuel evap canister
shift boot
radiator
all free
FZJ80-
AC compressor $80
AC condensor free
consol? not sure if this is from the 80
hood shock pistons
FJ40-
heater blower and housing
skid plate
bezel- $10 (I have 2)
older long jump seat frame
older style passenger door
rear swing out door
FJ40 windshield frame free
FJ40 older style passenger hard top side free
5 steel white spoke 15x10 8 lug wheels $50 for the set
I will gladly take all the free fj40 parts out of your way.
if the FJ60 smog pump and air rail are available i would be interested
All parts found homes and I am now living in Montana. Sorry, I guess I should modify the first post to reflect that.
"85 FJ60 heater blower
igniter"
Is this possibly an igniter from an fj60?
I think I might have an igniter up here in Jemez. If you are interested send me a picture and I will do some digging tomorrow.
