Cruiser Parts for sale! (1 Viewer)
N KY
Posting for Gary S. located in central/eastern PA... contact Gary directly!
Split transfer case from 82 FJ60 119K miles. Still on transmission,
works fine and sounded fine. Transfer case $250 transfer case and
transmission (transmission works fine) $250. That's right, selling 'em
together saves me the trouble of splitting the transfer to get it off the
tranny.
Split transfer case from 83 FJ60 126K miles. Has been removed from
transmission. Transfer worked great before removal from truck, and internal
components look fine. $250
Shifter for split transfer case works fine and is a complete assembly
$40
Transfer case from 73 FJ40 yes this is the three speed transfer case
and is the strongest version of that transfer case that was made. Excellent
condition worked great in truck before removal. $175
Vac shift transfer case from behind a three speed tranny. Look to be
in good shape both externally and internally but I didn't drive the
vehicles from which this was removed. $100
Power steering boxes good shape: FJ60 $125
Solid axle 4Runner/Toy truck (79-85) $85
IFS 4Runner Toy truck $85
Front driveshafts good shape no dents Ujoints are all free, splines
are straight:
82 FJ60 double cardan $85 81 Toy truck double cardan $75
84 Toy truck double cardan $75 86 Toy truck double cardan $65
83 FJ60 rear driveshaft $25
75 FJ55 rear driveshaft (for a four speed installation) hard to find
$45
82 FJ60 front axle complete from Aisin hub to Aisin hub. Works great
knuckles leak needs resealed. $215 If you just want the birfs and outer
axles, and disc brake components price is $200.
ARB front bumper with winch mounting capability bought for a 95
4Runner. Nice shape, one through hole in a cross brace has been
torch-trimmed but not noticeable when mounted nor does it affect the
integrity of the bumper. $250 pickup only.
85 FJ60 inner front axles (no birfs) good shape splines are straight
either side $20 each
FJ60 Aisin hubs (the best) $90 pair FJ60 birfs with outer axles $45
each
88 Corvette multiport fuel injected engine. Complete injection setup
intact, engine has aluminum heads, and comes with starter, flywheel for
auto trans, (engine came form a car with auto trans), water pump with
pulley, and some brackets on the front of the engine. Exhaust manifolds
still attached and in good shape. Distributor undisturbed. Also included is
a (damaged) aluminum bell for mounting a standard tranny on this engine, a
regular flywheel with what looks to be a relatively new clutch disc and
pressure plate mounted on it. Wiring harness and ECU NOT INCLUDED. This
engine smoked a bit of blue but has decent compression. Price is $400
Disc brake setup from an 83 4WD Toy mini truck. Includes birfs and
outer axles, rotors/calipers, Warn hubs, and knuckles. Quick sale price
$100
NV4500 five speed trans from a Dodge 4WD truck needs freshened up no
shifter $275
78 FJ40 four speed transmission works fine $175
Windshields pickup only will not ship $40 each: FJ55, FJ60
Rear crossmember with tranny mount 83 FJ60 good for five speed tranny
installs $20
3.70 third members 119K $60 each two for $100
Aisin solid axle mini truck/4Runner hubs very nice shape $75 pair
Aisin IFS truck hubs very nice shape $85 pair
Aisin IFS hubs nice shape but painted black!!!! $75 pair
Aisin hubs Suzuki Samurai like new $40 pair
Set of five (5) really nice BFG mud terrain 32 X 10.50 X 15 tires
mounted on 8" black rock crawler rims. One tire has less than 200 miles on
it, the others less then 2000. One tire has a small cut on the sidewall
that has been professionally repaired and has never leaked air since
repaired. These are nice tires and wheels pickup only. $400 the set of
five.
All parts located in northeast PA near Paragon and Rausch Creek off
road parks. Prices do not include shipping, I will ship anything at buyer's
expense except the ARB bumper, windshields and tires and wheels . Hit me
off list at shmukter@pa.metrocast.net, GSCHMAUCH@cartech.com, or by phone
home 570-668-2489 work 610-208-3792.
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
