Cruiser is running better that ever!!!
Discussion in '60-Series Wagons' started by 3puttcop, Jul 6, 2005.
  1. 3puttcop
    3puttcop
    332
    1
    Aug 11, 2003
    North Florida
    Boy is my cruiser running good. I maybe put 2k miles a year on my cruiser so I have not changed oil in a year or more. Changed it yesterday and switched to 20W-50. Changed from 10W-30.
    It seems like my engine is running much smoother, and quieter especially when idling.
    Has anyone else experienced this effect from an oil change or a viscosity change?
    Or is it just a placebo effect?
  2. Tapage
    Tapage Club 4X4 Panamá SILVER Star
    23,341
    1,369
    Apr 4, 2003
    Panamá
    yep is more thick, is better to low compresion o used engines .. :D also did you check your oil press, is much better now .. :D
  3. 3puttcop
    3puttcop
    332
    1
    Aug 11, 2003
    North Florida
    Pressure did move up. It was below center now its now a little above center.
  4. 2badfjs
    2badfjs
    5,522
    4
    Jan 26, 2005
    in the garage
    interesting..............
    i think i'll try that to get the pressure up in my 40
    great info THANX! :D
  5. Tapage
    23,341
    1,369
    Apr 4, 2003
    Panamá
    so that they are the friends .. !
  6. swank60
    swank60
    1,484
    244
    Aug 26, 2002
    One of Four Presidential Flying Saucers
    Something I did recently that made a HUGE difference in performance was switch over to NGK plugs. Amazing the difference. (was using Bosch dual spark plat. plugs)
  7. Liam
    Liam
    4,548
    Media:
    31
    Albums:
    4
    12
    Feb 10, 2005
    in the nappy dugout
    Toyota engines work a hell of a lot better on NGKs. Even Jap made boat motors run better - some Jap boat motors wont even run on anything but NGKs...wierd like that, but it is true.
  8. Liam
    Liam
    4,548
    Media:
    31
    Albums:
    4
    12
    Feb 10, 2005
    in the nappy dugout
    so is there a consisous (sp) that using 20W-50 is better for your motor?? I use 10w-40 synethic blend....maybe is should switch to a heavier wt oil...
  9. swank60
    swank60
    1,484
    244
    Aug 26, 2002
    It really depends on your oil pressure and performance. A lot of folks use the Delo 15w40 - I do during the winter and get great pressure, and there's a ton of detergents and stuff that help keep everything clean.
    If you're using 10w40 with good results, stick with it. Where you are, you're not going to encounter the ambient heat that I do here in TX, which is one consideration for the heavier oil. If you're getting a lot of noise and other unwanted performance issues, I'd say step up to the Delo 15w40 and see if that works well. If not, then go to the 20w50.
  10. sportbiker929
    sportbiker929
    463
    Media:
    3
    49
    Jun 1, 2005
    Oakley, CA
    Amsoil 15w40 heavy duty diesel marine oil is what I use. Excellent stuff!
  11. WALoeIII
    WALoeIII
    451
    2
    May 18, 2004
    Seattle, WA
    I just put in some Mobil 1 "Extended Protection" 15W-50 Synthetic, supposedly good to 15,000 miles. So far so good.
  12. magFJ60
    magFJ60
    230
    Feb 7, 2005
    Alabama
    Is 20W-50 thicker than 10W-30 or should it be the other way around?
  13. sportbiker929
    sportbiker929
    463
    Media:
    3
    49
    Jun 1, 2005
    Oakley, CA
    20w-50 is thicker, therefore higher oil pressure
