So you know I've got this new-to-me JDM HDJ-81. Its cruise control (known as "A/D" on the dash) works very intermittently. I prefer to use cruise control whenever the road permits. I've checked all fuses under hood and in cab. Today I tried to engage cruise numerous times, I'd almost completely given up on it, and then after about the tenth try it surprisingly worked and continued to until I shut it down. I later went out in it again and the cruise control wouldn't work. What gives?
More info: When I depress the end of the set lever on the column the dash illuminates "A/D", so that's not the problem. It just won't (often) engage/take throttle control when I pull down to set speed. When it does engage it cancels as normal by pulling back on the lever, or accelerating when I push upward, etc.
