Cruise Control doesn't work
Israel
Hi All,
My cruise control doen't work at all.
That means that when I press the On/Off button on the CC lever, nothing happends and no light on the gauges turns on.
I am suspecting a fuse. Where is the CC fuse located?
Any other ideas?
thanks,
Aifer.
Pretty sure you turn it on and then press set. Then the lights will come on signaling that the speed is being held. Have you tried that?
It also won't work if there are any active codes.
Indeed 2 codes:
1) C1268
2) B279A
I believe the first code was logged when I had my Center Diff lock issue (solved by cycling it)
The second code is due to faulty connection with the key? I had an issue and a key battery replacement solved it,
I may need to erase both codes - will try my ODB2 SW.
thx.
Indeed 2 codes:
1) C1268
2) B279A
thx.
Erased the codes, still doesn’t work.
Does anyone have the fuse locations for the LC200?
Location depends on year. Not sure what you have. See below.
my LC200, 2008 has the 4,7 petrol engine.
The fuse box is differ from this link. does anyone have my fuse boxes' diagrams?
You can go to the Toyota owners website and enter your vehicle info. You can then download manuals which will have the fuse box diagrams.
Hey Guys,
I found the CC fuse, 5A, ECU-IG NO.3 (in the fuse box under glove box) - fuse is OK.
Spoke with the previous owner and her said he never used the CC.
Sounds like the issue i have with the Center Diff Lock.
Any ideas?
thx.
Some folks suggested to replace the steering wheel airbag clockwise spring ad a solution nfor the CC.
