Cruise Conrtrol Actuator - anybody opened one up yet? (1 Viewer)
Spokane WA, USA
My cruise has been pretty much inop since last summer - it started dropping out on the freeway whenever the engine came under a load (climbing a slight grade), and now it won't even work more than 10 seconds at low speeds on flat ground. The Cruise light stays on when I turn the system on and does not flash or generate a code.
I'm going to start troubleshooting, but in the meantime I was wondering if anyone has opened up the actuator to see if it is repairable or is it a 100% throw away unit.... If I can drill out some rivets and clean it out, that would be cool.
Thanks. Oh yeah, I have the FSM and a meter, but any troubleshooting advice would be nice.
John
Wichita, KS
Virginia Beach, VA
Did you try cycling it from stop to stop a couple times? That usually works pretty good.
Spokane WA, USA
The following thread has some info and the pic is of the inside of the unit installed in my '94. There isn't much if anything that one can service. I cleaned the contacts on mine and it helped but beyond that get out your checkbook.
https://forum.ih8mud.com/showthread.php?t=16558&highlight=cruise+control
That helps a lot, but in looking at the pic I just don't understand how cycling the actutator manually, as recommended elsewhere, would do anything to "clean" those contacts. It just doesn't make sense. If they were sliding contacts, like on a rheostat, yes.
Is there anything else inside that might be fixable, like the motor itself?
John
Spokane WA, USA
Yep - several different times. No workee.
John
Wichita, KS
The motor may be, but as Dan mentioned it is not a field serviceable unit. You'd have to procure another unit and install the used motor. If you determine that the actuator is the problem your best bet is new $$$$ or www.Cruiserparts.net
Ipswich, MA, North Dakota, Phoenix
You might try cleaning the plug connectors. Mercedes had an unusual number of cruise control computers fail, and found that the connectors were slightly corroded, causing the failure. Just a shot in the dark, but what the heck? Good luck. Ned:cheers:
MoGas
Central Scrutinizer
GOLD Star
Air Mobile
I have a problem with mine in the morning. I turn on the Cruise then set speed and it flashes at me. If I turn the car off and restart it usually clears up and works properly. Sometimes it takes two restarts.
Dave
North Front Range, CO
Mine is working then it cuts out then back on right a way or it cuts out all the way and doesn't work for a day or so.
Lka1988
Wheeling in scale
Phoenix, AZ
Mine doesn't work at all. :flipoff2:
Oh wait, that's a bad thing.
