KingAir Driver
Ok... So the PO stated when I bought the vehicle that he had replaced the alternator with a high output single wire AC Delco (unknown amps) internal regulator to run the snow plow he had installed and that the ammeter was not hooked up. He had also replaced the points with electronic. So as I was cleaning up the 5th grader wiring connections and I found a few wires that had burned for unknown reasons. hmmm... The PO installed a 10 gauge wire going from the Alt into the cab, then another one came out going to the +Batt with a 16 gauge fusible link. ????? This got me concerned as to why the alt was not going to the +Batt and then onward to the ignition and so forth.
So I start taking apart the wire loom where it looks "un-original" and behold the White-Light Blue main wire is totally fried, all the way to the cluster. Both 10 gauge wires were running to the the + side of the Ammeter, and then a jerry rigged connection from the ammeter to the ignition and fuse box.
OHHH and the Blower Vent tube is totally melted in the middle !!! This sucker must've been HOT!!
I'm thinking he hooked up the high amp alternator to the stock wires and melted everything from the ammeter to the engine. The Neg side post of the ammeter looks toasty, thoughts?
If I were to fix this mess without pulling the whole harness, because it ran and everything worked. Would I just need to run Alt to +Batt , + Batt thru fusible link to + side of Ammeter post, then a link from ammeter to the ignition and another to the fuse box?
So above, you can see the nightmare splicing... top left White/Blue goes to fuse box (wire ok), then next to it is a splice going to the ignition (metal tie), then the blue connector splice went to the ammeter. Don't worry it was covered with electrical tape. The Black/Yellow wires are also spliced together right there (metal tie).
Lastly here's a pic of the alternator. Only one wire connected. What are my options for another single wire (since the harness wires are long gone) that mounts in the stock location, lower amps? Any help is appreciated.
