the PO or his mechanic really screwed up the bolts on the crankshaft timing cover. Now I'm not sure the screws are the right dimension. Anyone have the dimensions of these B and C so I can double check their length?
Starting from the one that is being unscrewed going clockwise. looks like I have 4 Cs where Bs should go. Why do these require longer lenths, or is it that the two shorter length bolts have limited bored out space hence they need to be shorter (but should be longer).
What's up with the Camshaft gear being red?
Seeing that I may need to prop up the engine by dropping the transmission/TC about 6" to get the camshaft out to get the plate off. I'll think I'll skip replacing that gasket. Fingers crossed it's not the one that's leaking.
