I'm starting to see cases of crankshaft pulley rubber damper dry rot and separation. This one was reported by a FB group user. I see this with older Tacomas (95-96) models that are well beyond 25 years old.
I've experienced these before on other Japanese engines with over 20 years and 250,000 miles. To me, the rubber damper is like any other rubber or plastic component that begins to harden and disintegrate with age. I can usually start to see hairline cracks in the rubber damper part that indicate the rubber became brittle and may soon separate from the pulley.
This is a maintenance item that I try to stay on top of before it becomes a problem. I need to check mine for cracks. I will replace mine at the next timing belt/seal change if I make it that far.
I wouldn't call this a common failure but one that I have seen become more frequent with high mileage vehicles that are over 25 years old.
