Confirmation needed before I pull my crank pulley off: when the crank pulley timing mark is at the 6 o'clock position (bottom) the crank pulley key will be at the 12 o'clock position (top), correct?
Edit: I went ahead and pulled the crank pulley; the key was almost at the top with the timing mark almost at the bottom, they were more like 150-160 degrees apart (or 200-210 the other way around), not directly across from each other, FWIW.
