- Thread starter
- #21
When I pull the pump I dont see a float type area like a cruiser carb. Can you discribe what it should look like? Is it in the diaphram? It does seem like the inlet needle is stuck. Can the inlet needle section be seen from the throat of the (there is a hollow shaft that usually sprays gas down the throat is this it?) carb?
fuel pump works fine
