Cracked or clogged heater core
Houston, Texas
I had the typical coolant dripping onto the passenger floor board from underneath the dash just left of the glove box. I read through a bunch of old threads about this problem and I guess I'll have to pull it out to see. Some have replaced the core and others have had it repaired. So my two questions are:
1. How do I determine whether it will be repairable or should be replaced?
2. It will be a huge time constraint for 3 weeks before working on this project. Would it be ok to buy a longer gates hose and bypass the front and rear heaters for three weeks?
2a. I would assume I could run the gates from the heater vale directly to the hard return line on the passenger side. Anyone see any problems with this?
Since ther is no faq for this fix, I'll do a complete writeup on it when I get the time.
Thanks,
Buck Buchanan
41 views and not a single reply.
Like Confucious told me, he said "Buck" (ya know cause we are on a first name basis) "your post has the same impact as the sound of one hand clapping"
and then there were crickets.....
Thanks Aaron.
I'm near the end of a front heater core replacement. I thought after I pulled it I would have the radiator shop take a look @ it. If they said it was repairable I would repair and reinstall. After tearing the dash ALL the way down and removing the core I decided I didn't want to do this again. So I bought new OEM. Around $260 bones for new. Worth it IMHO.
Guess you could bypass like you suggested. You'll have fluid in heater system so you might want to cap it somehow. Also have less area for the coolant to flow. Watch your temps.
Took like 200+ pictures on the tear down. They have been extremely helpful on the re-install. Mostly because I only get an hour here and there to work on it and my short term memory is shot. Seeing a picture of where wires were routed and clipped = 1000 words easy!
Brian
Bypass it and replace your heater core before next winter...
I appreciate the reply Brian.
I hear ya on the pictures. When I did my HG the pictures were invaluable for reassembly.
I have done the RT temp guage mod so no problems on watching the actual temps.
Buck
Not one that was very detailed.
I live in Houston so not to much of an issue really. You can bypass the front and still retain the rear heat if needed.
Buck
