Crack in da head 🧐
More info here:
Lots of good info. Looks like pay the piper now or later.
I have no idea what you must be doing under the hood to find that.
Just checking fluids and making sure everything is up to par. I would see oils there end thought hmm that’s odd. Would clean it and then see oil again.
No Jarco, they do several engines a year for dealerships. They use all Toyoya seals and parts. What’s interesting is it looks the crack is in pretty much the same place as some of the others that reported cracks.
No worries, you really gotta zoom in to see.
I work in testing field that deals with looking for discontinuities in materials. That does look like a crack as evidenced by lightning bolt pattern. If you wanted to be sure of your diagnosis you could perform a penetrant test on the head and would be cheap and easy to confirm that it is in fact a crack.
ceylonfj40nut
Waiting for Barn Time
TX
Run it. Check in a month. If it grows worry about. Drive it as you usually do. Don’t baby it.
That’s what I’m gonna do. I drove from New Orleans to San Antonio about a month ago pulling a trailer with it leaking. Had no issues so will probably just run as is for awhile.
FMC80
GOLD Star
Beyond
Agree with the dye penetrant. Cheap and easy way to confirm it’s actually a crack.
TomH
Seattle
I'm pretty confident there is a crack in that head. If you look at the thread I linked several of us have had the head crack in the same location. The thing is the crack is not in a critical location like by a water port or combustion chamber. It will leak a little oil that may make it to the exhaust manifold and smell bad, but not likely to cause any other issue. I ran mine for over 30K miles and the crack was there when I bought the truck. I suppose that given enough time/miles the crack could propagate to a bad location but no indication that has happened to anyone.
Maine
If you took a microscope to every square inch of your vehicle you would find dozens of "maybe this will be an issue in 5 years" things. If I were to talk like a dick I'd say drive the damn truck. 🤷
Oil is more likely from valve cover gasket than “crack”
Initially that’s what I thought, replaced gasket. Then saw the oil again, at which point I cleaned and saw the crack. Appreciate everyone chiming in. As Tom mentioned, not in a critical area so will just run it as is. Just gonna throw some sealer on it and run it. Now on to rebuilding a knuckle. Always things to do on these trucks.
Jersey, 07740
Yeah thinking just some type of weld or stitches. Yes engine is really clean basically a fully rebuilt engine from Jarco from top to bottom. It’s really nice being able to actually work on things on the truck and not get covered in oil.
jarco is pretty good with their warrantees, they should cover anything except the external sensors. we used them all the time at the dealership and never had a problem with the motors. do they still give you a pocket screwdriver and m&m with the new motor?
Yes got the pocket screwdriver, but no M&M. I went and picked it up at thier shop so that’s prolly why.
