I'm in the middle of a complete rebuild of my front axle/ring/pinion/knuckles and brakes on 81 LC. I found out during research on here that it was actually a 55 axle housing someone put on my LC. After checking brakes and knuckles it looks like it is late 70s early 80s diff housing.
So my question is... I have completely disassembled one side without any issue. Got the axle and birfield out without a snag. Moved to the other side and there isn't enough play to get the birfield out of the knuckle, even when I line of the flat portion of the birfield to the knuckle bearings as described in Toyota manual. It is tough to put traction on a greased axle without any thing to pull on.. but its not at all like the other side. Any ideas? Could the axle be stuck at the ring gear? Can I loosen the knuckle bearings to get it out?
Second question is in regards to reassembly. The Toyota manual has 3 pages describing how to determine the thickness for knuckle arm shims with several special tools. It also describes preloading before tightening anything. Does anyone have experience with this? I'm replacing all the seals, shims and bearings. Should I just put the same thickness shims back?
Last question is about replacement parts. I bought a "complete" knuckle rebuild kit from Cruiser Outfitters. I looks like in only has enough seals for the outer knuckle seal but the inner is not included. My out seal metal frame is all bent from PO overtightening (which is why it probably leaked!). Looked at SOR and their kit doesn't include the inner seal either. Don't understand why a complete kit would only include 1 of 2 seals... especially when they always leak!
Thanks for all the help. Can't believe I got this far into the rebuild with little issues!
CD
CD
