Okay, So I was able to get my intake/exhaust manifolds out today, and was going to get them milled. Upon inspecting them I did find some hairline cracks. Can you all take a look at the pics and tell me if it is worth having them milled or should i just get a new set of manifolds?
the cracks are in the center of the first picture and the 2nd picture is a close up of the first....
Many thanks for your expert opinions... before i go waste money on getting them milled if should actually be looking for a new set....
By the way, for those trying to take the manifolds off for the first time this is how I did it.
1. Remove all bolts holding the manifolds to the block.
2. Remove the 2 14mm bolts holding the cooler to the block.
3. Remove everything as a Unit
4. After unit is out, remove the cooler and J-pipe from the intake manifold iwth a plumbers wrench.
I hope that if someone else has a similar problem the above steps might help....
