I'm replacing my fuel filter for the first time as part of trip preparation. I always carry a spare, but have not needed to replace it. And the bleeder valve looks like someone prior has put it in the wrong spot. It is on the inlet side of the filter, so the only air that would get bled off would be between the injector pump and the filter inlet. It seems to me that the bleeder valve should be on the outlet side of the filter (the left side) so you could bleed the filter.
I'm thinking someone mixed up the bolts that connect the banjo fittings to the filter housing. One is just a bolt, and the other is a bolt/bleeder valve and they probably would fit into either side.
But it would be nice to confirm this before I mess things up by reversing them. Yep, I've messed things up before!
Thanks for any input!
