- Joined
- Sep 9, 2004
- Threads
- 186
- Messages
- 11,038
- Location
- Boise - Idaho
- Website
- www.snlandcruisers.com
I don’t think this is anything new info wise, just the opposite actually. Let’s beat the horse one more time though.
Here is what we have seen in my shop in the last three months.
My 95: new engine, all new cooling system, everything OEM. Radiator used but only 2yrs old and is an OEM (TRad) that has only ever had red in it. I run around town at 182-186*. In traffic, idling with A/C on high and 95+ outside temp, it will hit 190*. I seen it hit 191* once so far, wheeling in 85+ outside, A/C on high. Timing set at 8*. Running red at a 50/50.
Customers 93: remanned engine we didn’t install. All new parts but most Oriely’s Chinese specials. Fan clutch was a “Topaz”. Cruiser even had hood vents cut in. Running around at 195-200*. Under load, a/c on, ect, I seen it hit 210* and this isn’t in 95+ outside temp. Running what looks like dexcool, don’t know mixture but it tested to -15*. Timing set at 8*.
97 CE: we just did a new engine in it. Top end rebuilt but short block new. All new OEM cooling system, except the rad. It’s an Orielys special but is fairly new and to keep cost down it was retained. Runs around town at 184-190*. Just under a mild load we have already seen 192* with a/c on ect ect. Again, only thing not new & OEM here is the rad. Running red at 50/50. Timing set at 8*.
What’s the moral of the story here? Don’t cheap out and use Chinese parts on your cooling system if you want it to run cool. We are seeing a solid 5* difference in my shop just using a Chinese rad vs an OEM. Whole China on the system and its running to hot.
Cheers
