zachmartin529
Landcrusher89
Hi Mud,
My FJ62 has about 240k on it and finally the water pump kicked it. I replaced it with a factory part and also had the radiator repaired, cleaned and pressure tested as the top tank began to leak. Threw a new thermostat and housing gaskets in it and flushed the system with one of those kits from the auto parts store where you but a hose bib in-line with the cooling system (had to cut a heater hose and now with I didn't but oh well). I burped the system but when I drive it, the temp will spike to hot and fall back down again intermittently, no matter if the heater is on or off. It won't do it when I'm cruising at a constant speed, but when there's partial throttle input or modulation in traffic it will jump up. Also when I've got my foot in it, the temp will jump up but not fall back down unless I snap the throttle shut. Do I still have air bubbles, bad thermostat, or is it something else entirely? Thanks!
