My '98 appears to be leaking coolant from a fitting that threads into the lower left side of the engine block. Attached to the fitting is a rubber hose that goes to the top of the oil filter assembly. I assume this must be for oil cooling purposes? The coolant appears to be seeping out from around the threaded fitting that goes into the block. I'll attempt to tighten the fitting, but it's odd that it would suddenly start leaking. Anybody else experienced a similar leak?
Thanks.
Thanks.
