Started smelling burning coolant.
Took a peek and saw it seeping out.
Anyone had this? Please advise.
Thank you. Are you certain that’s the same leak?Live help: Coolant leak at water inlet housing and water pump
I have a severe coolant leak at the water inlet housing and water pump joint. I have searched for some guidance, but looks like I can address this with out digging too deep. It seems like the o ring has failed. Does anyone have a good PN? Also- yes I am aware that the red hose is too short...forum.ih8mud.com
99%Thank you. Are you certain that’s the same leak?
I didn’t have the one in your picture go but I just had this happen to mine at the rear of the engine at that tee. The hoses were fine it was the clamp giving out. Easy fix, new stainless hose clamps that screw to tighten instead of spring loaded. Might try that before doing anything too drastic.Started smelling burning coolant.
Appreciate the input. I’ve looked all around and that’s the only place with seepage.I didn’t have the one in your picture go but I just had this happen to mine at the rear of the engine at that tee. The hoses were fine it was the clamp giving out. Easy fix, new stainless hose clamps that screw to tighten instead of spring loaded. Might try that before doing anything too drastic.
