Coolant Additive
Kalifornia
Hi Folks-
I'm trying to change out all the fluids on the BJ-70 I bought...
A friend told me I need to add an additive to the AntiFreeze when I use it in a Diesel Motor. I guess Ford recommends this, but thankfuly I don't drive a Ford :grinpimp: . Are people doing this on Toyota Diesels?
Thanks
Seth
The Dude
Foam Lake, SK
Nope, it has to do with the engine having coolant sleeves around the pistons, as I understand it. Something about detonation of the coolant drilling small holes through the block.
not an issue with toyota engines.
Greg_B
The Dude said:
Nope, it has to do with the engine having coolant sleeves around the pistons, as I understand it. Something about detonation of the coolant drilling small holes through the block. not an issue with toyota engines.
Correct from what I have gathered as well. It's a wet sleeve vs dry sleeve issue if I am recalling correctly from looking into this a number of years ago. The additive adds a sacrificial surface to the wet sleeve to reduce cavitation/detonation issues caused during the compression ignition stroke on a wet sleeved block.
hth's
gb
dieseldog
She idles just fine . . .
GOLD Star
Houston & BFE
These additives are called Supplemental Coolant Additives (SCA's) and are required for wet sleeve designs. The SCA helps to prevent local pitting from cavitation which, over time will ruin your IH/Ford engine. The SCA "wets" the surface more efficiently and prevents the effects. As your pistons move up and down inside the cylinder, they do not do so in a completely linear fashion. Force vectors and such cause it to move somewhat side to side as it makes its way up and down in the cylinder. This sideways motion causes vibrations and hot spots that actually create localized boiling. The more pitting that occurs, the more cavitation will be suffered.
Wet sleeve designs must add SCA's at certain prescribed intervals else they lose their protection. It doesn't hurt to use such products in dry sleeve designs either--be they gas or diesel. There's a product called "Water Wetter" out there that will help give more efficient heat transfer all around the cooling system--the block, heater core, radiator, heat exchangers, etc. Use your own judgment here.
Greg_B
Well said dd. Much better explaination then my recall attempt...
gbl
