Did a Cool Cruiser Lock Box w/ Tuffy double cup holder in my FJ62. They don't offer a custom fit box for the FJ62 do to the heater under the center concole but this worked with very little fabrication.
1--In the pics you can see I just slid the lower bracket that was provided back a few inches and fabricated a slot to use the temp control (Had to bend the lever to make more room aft and used the old sticker). The hot air will come out the sides and bottom (if I ever use it).
2-- I then drilled new mounting holes and fit the support braket to the box.
3--One note, before you mount the braket make measurments and drill holes in the braket that match the old mount points for the old center concole on the heater.
4--There are two rear mount bolts that where pre drilled in step 3, I just used those plus a self tapping screw up in the front of the box to secure it down.
5--The cup holder was built by Tuffy and if you use it you may have to trim a little plastic around the sift lever but thats it, simple and clean!!
Drop me a line if you want more info. Mike
