RET2
Would just pulling the battery in the spare work?
I agree. I purchased the same tray and have been enjoying it daily.
How long will the ice cream last?! Never thought. Road trip ice cream sandwiches !Yea love the cool box. Use it all the time with beverage and ice cream, meat when we do grocery.
Contact @Markuson, he has vast experience with this fix.anybody have their coolbox fan not working? I just tried to pull the fan and it requires evacuating the A/C system. I can't find a why to pull the paneling and leave the evaporator in place to access the fan motor.
You can get to it without disconnecting the ACbutIts a huuuge PITA.
To top off the frustrating disassembly...after you tear everything out...there this ONE final screw that points directly upward....and is nearly impossible to get to. I mean like...not even a tiny ratchet with a phillips bit can fit in there. I finally ordered a special, very weird “screwdriver” that is flat, and that has only the tiniest, shortest phillips on it...then I bent it 90 degrees. Only then could I get at the screw...barely.
Here that “screwdriver;
When I finally put it all back together, I think I decided to leave that screw out...as it seemed utterly pointless except to induce pain and frustration.
I found out the hard way that I could have avoided the AC mess.... but here’s a taste of the fun you’ll have digging down to the fan...
Don’t do this:
My advice would be to see what various Toyota dealers quote you for the job. Another mud member got his done for around $300...which is a bargain for all the time and hassle getting to it.
Thankfully the fan was all mine needed... but man what a pain.
I regret not photographing my experience when I did this repair myself last month and ended up succeeding with far less suffering than expected. There's no doubt that the project is a pain as you say, but I was able to get it sorted in less than 3 hours or so without removing either of the front seats. It really came down to simply being methodical and accepting the fact that there will always be another screw that needs to be removed before you're able to finally swap in the new fan/motor.
I'd read your posts prior to starting the project and was prepared to track down the single upward-facing screw at some point in the process. After I finally found it, I did some very careful investigating (i.e. inferring) and decided that the area surrounding that screw was not particularly critical. A bit of pry-bar action was all it took to fully remove the insulating plastic from that particular screw, without needing to reach the philips head at all. It's directly below the condenser lines, so I had to be careful where I applied pressure. However, after pushing straight upwards, with force applied to the area immediately surrounding the shaft of the screw, I was able to deform the tapped plastic enough to release the entire piece. Fortunately, the risk turned out to be worthwhile, because the plastic into which that screw is seated is more or less inconsequential to the fit or visual finish of the cool box – it goes into the lowest point of the dual-walled insulated walls of the box. As an added bonus with my brute-force technique, I was able to use the now-deformed tapped hole to reseat the insulated wall during reassembly by simply pressing the still-in-place original hole onto the still-in-place screw then pressing down until I could reclip the removable snap-clips.
Luckily, I put the time and effort into the repair right before I'll surely completely ignore the cool box during winter here in New England.![]()
View attachment 2462711View attachment 2462714
Don’t do this:View attachment 2462717
If their out of the one labeled for LC, just order the one branded Lx. Fits the same. Mine did.
