Cool Back Up Light Mount (2 Viewers)
For those with rear tire mount bumpers.
While it was designed for certain Jeep wheel patterns, I can't see why it wouldn't work for our 100s.
Cool. Actually, it might not be plug-n-play on a 100. If the bolt pattern is 5x114.3 (which I'm not sure about), then the bolt circle is about 36mm smaller than our 5x150.
According to manufacturer:
It was designed to fit the Jeep TJ and YJ 5x41/2-inch wheel patterns, but will also fit the '86-and-older Jeep CJ 5x51/2-inch wheel patterns with some modifications.
A saw and a little modifications and it will fit fine. Or you could just make a bracket and bolt your light on it, probably cheaper and a less of a PITA getting it to fit properly
peg, go fix your lightforces before you worry about adding more lights :flipoff2:
btw that setup above would rattle like crazy and drive me nuts.
Working with Joe on my light problem (maybe the relay); and, why would it rattle?
i know you were, he stopped changing my diff fluid to help you :clap: It would rattle because it's not a solid mount, think of a tow receiver in your hitch, they rattle.
Think you'd be able to hear it, considering it's location? Doubt it...
I have been stumped for the past few days on this rattle coming from the back at 70-80mph. It's like a knock and a bang going down the road. I adjusted my mirrors and saw my little tuper-ware bumper flapping around. I had no idea how much it flapped, but I guess she flaps enough to be heard inside.
so yes, any rattle will be heard.........
^you just need to drive faster so the sound can't travel forward.
Ok, maybe it's not "cool" but it did look pretty effective. As for the rattling, I am sure it could be installed such that it doesn't.
IH8RATTLES
I can hear a receiver rattling in my bumper, so I bet I could hear that.
Then your receiver is too loose. Seriously!
