Convince me yo get a diesel!!
Let’s see… what I like about my diesel…
I’m biased because I think that diesel engines make more sense in a heavy truck like a Cruiser, they get substantially better fuel economy. That’s why they are more common than gas engines in other places in the world where gas is twice the price (which is everywhere else, gas is cheap even now in North America)
- Diesels are subject to much greater compression and more violent combustion forces, tolerances are tighter in compression ignition engines and parts are over engineered, this makes them inherently more reliable (though we know Toyota gas motors are well made too).
- Fuel economy, well we already know this…
- No ignition system, this makes tons of sense in a vehicle that is designed to be used in remote locations, as noted above, water crossings aren’t as much a worry. Flakey points, coils and other non electronic ignition parts aren’t a concern. Alternator just die? Your motor will still start and continue to run long after the alternator gives up the ghost.
- Consistent idle and power characteristics, my diesel never showed the roughness or the finickiness that a carbureted gas engine likes to exhibit (carbs suck, though fuel injected gas engines do just fine with altitude and temperature change etc.) It always idled the same and never stalled. This is a great characteristic when crawling in 4 low.
- Better low end torque, my worn out 2H seemed to have better get up and go, no rev and slip the clutch until the motor overcomes the weight of the truck (ditching the 4 speed if you have one and installing a H55F with a lower 1 st gear ratio would help).
- Less maintenance in terms of tune up schedule.
- Properly tuned diesel engines do not smoke or stink and Toyota diesels are relatively quiet.
Things I didn’t like…
- You go broke doing oil changes, I’m not sure what a 2F takes for oil quantity but my 2H drank approximately 11 litres, or 3 gallons of 15W40 per change. Turbo’d motors require a tight oil schedule because the tiny oil passages through the turbo don’t like dirty oil, not changing your oil regularly in a turbo motor will shorten its life.
- Speaking of dirty oil, have you seen used diesel engine oil? Oil changes are messy and if you like your concrete driveway clean, find a buddy who doesn’t and change your oil at his place!
- They can be hard to start in very cold conditions, compression ignition engines like heat and only really burn efficiently when running at operating temperature and keeping them warm in severe winter conditions can be hard too. You need to block the rad with shutters or a cheap piece of cardboard (this really looks Redneck).
- When they do crater diesel engines are expensive to repair, parts are considerably more expensive.
- Diesel can be hard to find in some locations, it’s not at every service station but if you do run dangerously low on diesel you can always pop into the local Quicky Mart and pick up a few jugs of Safola or siphon some jet fuel out of a plane at the local airport. Try that with your gasser!
- NATO Spec Electrical System only sounds cool - 24V light bulbs starters and alternators are not usually available at your local parts store and the underpaid high school kid behind the counter will look at you like an idiot for asking for them (at least the headlights are 12V). Carry extras.
- Don’t run 12V electrical parts off one battery, it causes an imbalance in the 24V system and the battery you’ve wired off never charges properly. This sucks because everything for the automotive world is 12V. Installing banks of 24-12V converters makes your truck look like a mobile hydro-electric substation and eats up all available space under the hood.
The 2F is a fine motor and really for most situations it’s adequate. Parts are cheap and they are everywhere, just like gas itself, but I’ve driven trucks with the 2H as well, and in my opinion, it made the FJ60, well HJ, a better truck (even my tired and desperately in need of a rebuild 2H).
Here is a couple of points that some others have not mentioned. I have an old carbed J@@p. If the carb gets off camber in any direction by say about 20* it barfs and stalls unless I rev the snot out of it. I have installed all the nifty little kits that holley has, but only got marginal improvment. My landcruiser has never done this to me. On that note, one could argue that efi solves this problem; however, if you lose a sensor the ecu goes to open loop mode, or limp mode. and your mileage goes to crap and the engine runs like crap until you fix the faulty part.
As I read fromt this forum, supposedly a quote from Peter Straub, alot has to go right to keep a gasser running and a lot has to go wrong to stop a diesel.
The diesel is safer to work on for a couple of reasons: 1) diesel fuel has a lower flash point than gas, 2) no high voltage coils.
On the minus side. It is a little harder to pull start a diesel if your batts die, but, as previously mentioned, it will run fine without batt power if it does not use electronic fuel management. And its really hard to find a 24v boost, and if you do find a company that does provide a 24v boost they charge more $.
Karl
Karl
Karl,
the gasser 2F asian carbs perform excellent at all angles, severe incline, descent, side hill. the holley or other american carbs suck on anything but level ground.
i do beleive it was Bruce L that made that quote up...
still the fuel injected diesel is the best for off road reliability...
if you need convincing then a diesel prolly isnt for you....nd leave it at that
Deisels are boring. Once you get the engine in shape you never get to do anything else to them other than clean the filters and that's not really engine stuff. While your friends have fun loading gas, you have to sit around waiting for them. You never get to do nothing. You don't even know it's a deisel by sound once the windows are closed. They also pull stuff without a twig while the others have fun revving and roaring and steaming.
Gas engines make life more interesting when it comes to the heavy stuff plus you get to do tune ups with plugs and stuff every 5,000 miles.
Kalawang
what ya want it for?cruisin highways? muddin?
i was once the fool who shunned any 'oil burners'... :whoops:
the diesel is the best thing i've done to my offroading prerequisites... the low torque is great as ya dont need to rev to get power and the chance of spin with risk of traction loss, is minimal...
have seen the po of my 40 have it under water (up to the windscreen) and just sit it there with no mods bar snorkel... when he climbed out the window onto the bonnet to check how it was goin, all there was to be heard was the 'glup, plup blup blup' of the exhaust gurglin up...
with a gassy, electrics would have died somewhere before the drive out for sure!:o
i'm, a converted gasso and will be stayin with diesel fer sure..:cheers:
anyways... thats my 5 cents worth... :bounce: :bounce2:
Kalawang
Haha...that's a good one. Ain't that the truth! :D
Amazing this thread is still alive. What a stupid question to ask, Convince me to get a diesel...... go buy some gas and be gone... :)
I enjoyed reading this thread. Some of the responses have been hilarious. To me a diesel Land Cruiser seems more like the "Jerimiah Johnson" of off road vehicles.
More to the point . . . I'm seriously interested in getting a diesel Land Cruiser (don't need any convincing) but have been hard pressed to find one that I wouldn't need to import. I think this would be a much easier decision for me if they were simply easier to find in the STATES. However, I'm not discouraged yet as the Land Cruiser is still a captivating vehicle. I know I'll get my grubby mits on one eventually, but it's not easy when I'm looking to avoid spending huge amounts of $$$.
Have you considered aquiring a local gasser with a good body and using the vast resources of our forum to do an engine swap?
You may or may not save money,but it will be done to a standard your happy with and it will be LHD.
Money is an obstacle most of us have to contend with,so turn it into a long term project that is done in stages
As you collect the items you need,you also collect the knowledge ;)
rosco,
I've been seriously considering that. Idealy, I'd like to use a late 70s early 80s FJ40 and convert that over to diesel if I went the swap route.
Is there a thread about swapping engines and what all it envolves with the other systems, transmission etc? I'm a novice to most of this.
Thanks
rjones25 said:
rosco,
Thanks
There is a wealth of info on this site re swaps. The 40 is an ideal platform as the lack of electronics make it easy .
The easiest way is to use a 2H 6 cyl as it should bolt right in and use the old gearbox. The 2H didnt actually come in a 40 but it did in a 45 which has the same engine bay.(see 1st pic below)
A 3B 4cyl was available in this model also(see 2nd pic)
but requires a little more work such as engine mounts and its own gearbox.
Diesel dont have distributors and coils and are similar in size to the gasser 6 cyl so it is generally more simple than say swapping a V8 into a 40
These both have their factory turbo versions of a 12HT and 13BT available in later models.
I would also consider using a 5sp to get the most out a diesel but this is something that could be done later.
Dont expect a standard diesel to be a powerhouse,they are plodders with lots of low down torque,more famed for reliability and good fuel economy
The search engine is your friend but throw up as many specific questions as you like if cant find an answer.
