I did the swap. It is a very noticeable improvement. When you get around to doing it, let me know if you need a hand or an extra set of eyes. In addition to the information here on MUD, here are a couple of threads on Rising Sun;
my swap and
Jeff Zepp's swap - both of these also include changing the engine. Fortunately, you will not have to do this.
Dropping the 3 speed transmission and t-case are very straight forward. Putting in the 4 speed and t-case will require tilting the engine because of the clearance issues with the frame cross member. Alternatively you could pull the engine, transmission and t-case out the front, then assemble it, then put it all back in as a unit. For what you are doing, I would recommend, just tilting the engine back.
Must have/must do items include;
- 4 speed bell housing
- Drive shafts; either modify the ones you have or get some from a 4 speed FJ40
- Pinion Flanges; many options but the key is the bolt pattern on drive shafts, third members and t-case need to all match up.
- Hole in the floor
You can keep your existing flywheel and clutch setup. If you decide to replace your clutch, then you will need to make sure your flywheel is appropriate for your clutch.
You can keep your existing t-case, but doing so will require you to get some additional parts (gears, bearings, longer bolts, etc.) so that it connects to the 4 speed transmission.
You can keep your vacuum shift system, but you may have to deal with some clearance issues. This is not that big of a deal.
