I'm in the process of doiing research for installing an Alpine HU I just bought.
I want confirm that the following instructions I copied from SOR is enough for me to get behind the dash to do the stereo install. (The following instuctions were taken from the installation instructions for the Center Diff Lock Switch):
# Removal of dashboard trim piece, 1993-94 models
1. Remove ashtray
2. Remove the two screws on either side of the ashtray sliders as well as the one about 2" inside the opening, on the top of the metal plate. Be careful not to drop it.
3. Remove the screw located under and to the left of the 3 switches along the bottom piece of the dash. (RHD Models)
4. Lower the steering column
5. Now place one hand at the ashtray opening and the other on the upright between the stereo and heater controls and pull gently.You should now have enough access in behind the dash to find the plug required.
Will this give me enough space to do the install of the HU?
Ron
1. Remove ashtray
Ron
