It's on the side of the transmission where the shifter connects to it. Normally when they malfunction they will through a CEL.
Can someone please tell me where the switch circled below is located? I used the FSM and volt meter to check the plug going to the amplifier. All was good except this wire. It should be supply 10-14 volts. It has nothing. Thanks!
Thanks
Thanks jsloden! I apologize if I hijacked the thread. It wasn't my intent. I rebuilt my cooling system last year and want it back!!
So I'm guessing do a continuity check from switch to amplifier connector? I have no CEL light. I welcome ideas/advice! you guys feel free to chime in. Thanks!!
Thank you sir! You've been a big help today. Here's one place I'm cofused (there are many!)... If I read the diagram ciorrectly, it shows the current comes out of the amplifier on #5/black wire. The FSM says there should be 10-14 volts coming in with engine running. #5 is the only wire that did not test good, it had 0 voltage with engine running. So I should test for voltage at the park/nuetral switch next? Thanks again!Amp draw check, continuity isn't good enough to check load. Just confirms that at least one strand of wire is connecting.
I would backprobe the #5 wire with the engine running, see what comes out. Make sure you're making a good connection to the spade in the connecter with is back probed.
Not going to be easy with the location of the connector.
If you don't have battery voltage there, I would say you may have to start there.
If you do have battery voltage there, then you need to go to connector IH1 - check there for battery voltage, then up to connector IG2 (which a fair amount of the A/C Amplifier wires seems to run through).
I'm pretty sure that #5 wire only gets +12V when you're actually cranking the starter.I can't thank you enough for your help! I'll give this a try tomorrow.
Landcrshr, you were correct! #5 wire has power for a second or two while the starter is engaged. Now I'm back where I started... I've tried two amplifiers with no success.... hmmm...I'm pretty sure that #5 wire only gets +12V when you're actually cranking the starter.
Thank you jsloden! I honestly can't thank you guys enough. I truly appreciate everyones time.The two quickest things to rule out are the low pressure switch and the thermistor. You can simply make a jumper with a piece of wire or a paper clip and jump the plugs. Should take 10 minutes. There's also the relay the on top of the evaporator box. If I remember correctly the voltage passes through the relay after the amplifier. So even if the amplifier tests good the compressor still will not turn on if the relay is bad.
maybe post #18I finally found time to jump the thermistor plug... Nothing changed, so I guess the thermistor is good. Though I did buy a new one and will replace it soon, just because that's the way I am...
Does anyone have a trick to removing the round relay above the evaporator (circled in red)? I wanted to get a part number off of it.
Where does the #7 relay 88630-20020 (circled in blue) live? I'm still looking for it...
Thanks again guys!
Was your bad relay the round relay, or the rectangle relay that I haven't found yet?There is a relay behind the glovebox that gave me the same problem on a 1996
