(Complete) Restored FJ40 2F Carburetor Accelerator Throttle Linkage Torque Rod Brackets Rods Kit (2 Viewers)
ToyotaMatt
Factory Focus-Point Mind-Set Approach
Supporting Vendor
GOLD Star
EAST COAST
Website
vintageteqparts.com
Restored FJ40 2F Carburetor Accelerator Throttle Linkage Torque Rod Brackets Rods Kit Set Up
- From Gas Peddle to Carburetor
" Everything Circled in Red "
- ALL parts media blasted Then refinished
- All New Rubber bushings , grommets , Cushions , Hair pin , Collars , Ball & Socket spring Clips
10mm hex x 35mm Long
Mounting hardware to firewall
The rest is ALL New OEM Toyota Genuine parts
- Please refer to parts Diagram below
I have gas peddles available also
I have Orange Boots also available
Please Inquire Any questions
$475
Matt would a ‘72 FJ55 Pig use a linkage like that as well or is it different? It currently has a 2F in it with a Weber but my friend is considering going More original. Thanks Tom
A FJ55 Uses Similar Parts as the 40 But indeed 55 specific ...
- a 2F would have used all linkage for sure , how ever a 1972 FJ55
originally , used linkage or a Cable type throttle i am Not sure on this fact?
- But , however i have Installed a late Model FJ55 on a 1974 FJ55 , and it
did require some tweerking , but was easy to update and upgrade at the end of the day
the biggest challenge was properly Locating the mounting spot for the
firewall Torque rod bracket .....
once i established that detail , the rest was plug and play .......
i hope this helps
just a fyi ,
i DO have ONLY 1 , complete 1/75-1980 FH55 specific Accelerator Linkage kit
in-stock , but only 1 for sure , and the 55 linkage parts and very difficult to find and source .........
it has taken me like 2+ years to gather all the correct needed parts ......
just a fyi on that topic
thanks matt
This Matt is the right guy for correct parts that work and fit.
I have owned many cruisers over the past 30 years and would look to Matt in a heart beat,,Thanks and good look find ing your parts Dave
i hope this helps
just a fyi ,
thanks matt
Matt do you have the carburetor linkage to fit a 1974 FJ40. Everything from carb to pedal, does not take the cable.
Tom
Tom
YES ,
i do , Including Some Recently Acquired and Discovered Cache of NOS Push and Pull Rods to .............. :D
Tom
ToyotaMatt,
Do you have any of these linkage kits from the firewall to the carb? '75 SA FJ40 w/ non-smog factory carb.
ToyotaMatt,
YES
i have More kits available '
