Colour matching/painting Safari Snorkle
Calgary, Alberta, CANADA
So I decided to upgrade my LX with some ARB's front, rear, side bars and a snorkle. I thought since it is the Pearl White all the parts should be colour matched.
I have seen a few pictures around with the snorkle colour matched. I really didn't like the texture of the snorkle. It doesn't look as good as if it was smoothed out.
So........
I started to sand them smooth and remove the texture and the flashing.
Spent about 45 minutes sanding the texture. I used a DA with 120 grit.
I plan to prime it tomorrow. I will be using a plastic adhesion promoter before priming. Although it is rigid plastic I will still add some flex agent as well.
Once it is primed I will spray it along with the front ARB. I'm still waiting for the rear ARB and front rails.
